initialize common block defined in a module in OMP
stydofe1
Define a common block in an include file, for example
 Test.ins
Common /test/ a b
 Then wrap up the include file in a module file, for example
 Module test
Include ‘test.ins’
End module
Basically I just define the common block in the module. I do not have issue to use the common block in the regular Fortran codes. However in OMP I define the common block as threadprivate and when I initialize the block for child threads with COPYIN directive, I got the error below.
error #7460: A common block name is required
Please let me know if I am not clear about the issue.
jimdempseyatthecove
The error message "A common block name is required" is self explanitory.
[fortran]
type    TypeThreadContext
SEQUENCE
... declarations here
end type TypeThreadContext
type(TypeThreadContext) :: ThreadContext
COMMON /CONTEXT/ ThreadContext
!$OMP THREADPRIVATE(/CONTEXT/)
COMMON /FOO/ A,B,C
!$OMP THREADPRIVATE(/FOO/)
[/fortran]
Jim Dempsey
jimdempseyatthecove
Normally you do not place COMMON data in modules because the name of the COMMON block you use will get pre-pended with a module prefex name
In your case the actual name might be TEST_MP_TEST
You will have to check, and the compiler may change the prepend now or later. It may work to scope the declaration
!$OMP THREADPRIVATE(test::/test/)
I haven't tried the above, don't complain if it doesn't work.
I suggest using the user defined type and remove COMMON though this may be problematic for your case.
Usually where you had COMMON /FOO/ A,B,C,...
you would make a user defined type (e.g. FOO_t) and declare an instance of FOO_t as FOO. Then you can !$OMP THREADPRIVATE(FOO). And reference variables as FOO%A, ...
In the event you have no variable naming conflics amongst your various COMMONs, then these not need to be in a typed variable. And you can forgoe the FOO%...
Jim Dempsey
stydofe1
The block has been defined as threadprivate in the include file,
Test.ins
Common /test/ a b
!$OMP threadprivate(test)
If the common block is refereed with the include file, the file with COPYIN statement is compiled successfully. But if it is refereed with the module file, which is simply a wrapper of the include file, OMP fails to compile with the error ‘A common block name is required’
I can not see the difference between these two methods. Is it a bug in compiler?
jimdempseyatthecove
But your "include 'test.ins'" is enclosed in "module test" / "end module test", thus making the enclosed "COMMON /test/" within the scope of the module test. As stated in earlier post, all members of the module, in this case "test" have a prefix pre-pended to the name. In the case of "module test" the module name is test, and the prepend text is "TEST_MP_", thus producing a COMMON block name of /TEST_MP_TEST/ (implicit name) for given name /TEST/ within the scope of module test (TEST_MP_....).
Had you used "module foo" in your example then the name would be FOO_MP_TEST.
*** Note, the actual prefix may be of a different form (_FOO_MP_) or some other thing.
module foo
REAL :: A
COMMON /TEST/ B
end module foo
produces
REAL FOO_MP_A
COMMON /FOO_MP_TEST/ B
Jim Dempsey
Andrey_C_Intel1
It looks like your program is non-conforming. Let's refer to specifications.
OpenMP:
A common block name that appears in a copyin clause must be declared to be a Fortran common block in the same scoping unit in which the copyin clause appears.
Fortran:
Use association is the association of names in different scoping units specified by a USE statement.
Thus you are trying to specify in the copyin clause the common block declared in different scoping unit, that is not allowed.  Though it is possible to list the variables from common block of different unit (not the common block itself) in the copyin clause.
Andrey
