intel(R) core(TM)2 duo cpu t6600 2.2 ghz
thouraya87
Hello
Please how many cores in this architecture?
I tapp this command in cmd.exe >systeminfo
I have
Processeur(s): 1 processeur(s) install(s).
[01]: x64 Family 6 Model 23 Stepping 10 GenuineIntel ~2200 MHz
Is it one core only??
in return I found this link that says they are 2 cores
http://ark.intel.com/Product.aspx?id=37255
Thank you
Ilnar
2 cores in one processor
see more http://ark.intel.com/
Ilnar
thouraya87
Hello
Please what's the diffrence between intel core2 duo cpu t6600 2.2 ghz and Intel Pentium dual cpu T3400 @ 2.16 ghz
Intel Pentium dual cpu T3400 @ 2.16 ghz has 2 processor or 2 cores in one processore??
which is the most performant between these two architectures??
Thank you
Ilnar
technical difference: http://ark.intel.com/Compare.aspx?ids=35583,37255,
in other words, both processors have 2 core in one processor die,
T6600 is newer architecturewith twice more cache size andhigher performance, better TDP, for mainstream notebooks. T3400 was for lower cost notebooks.
todays there are newer architecture processors: core-i3, core-i5, core-i7
