problems with mpich
parsa_banihashemi
I have a cluster with windows HPC server 2007 service pack 1
I can not run communicative commands of mpi on the system.
when I run the following simple code on 2 nodes using one core on each:
use mpi
implicit real*8(a-h,o-z)
call MPI_Init ( ierr )
call MPI_Comm_rank ( MPI_COMM_WORLD, my_id, ierr )
CALL MPI_COMM_SIZE ( MPI_COMM_WORLD, NUM_PROCS, IERR )
print*,my_id, NUM_PROCS
call mpi_barrier(mpi_comm_world,ierr)
call MPI_Finalize ( ierr )
end
It does the first printing, but On mpi_barrier, It return error: rank 0 unable to connect to rank 1 using business card(33709,....)
mpi_barrier error,
I have the sam eproblem with all subroutines: mpi_bcast, mpi_reduce,.... and all subroutines that need communication.
But If I want it to print ranks, or each cpu do some operations on its own, It does. I have run this code with the same version of mpich on a pc with windows xp, cammunicating through ethernet with a laptop with windows vista. please help me out.
Parsa
