NUC10i7FNB / Intel® Core™ i7-10710U CPU @ 1.10GHz / 32GB RAM / BIOS 0052
Windows 10 and all drivers updated.
This has been going on for a couple of weeks. The fans are constantly running at full speed. Checked the temperature today, HWMonitor reports:
Temperature 0 88 degC (190 degF) (Package)
Temperature 1 83 degC (181 degF) (Core #0)
Temperature 2 93 degC (199 degF) (Core #1)
Temperature 3 93 degC (199 degF) (Core #2)
Temperature 4 84 degC (183 degF) (Core #3)
Temperature 5 82 degC (179 degF) (Core #4)
Temperature 6 80 degC (176 degF) (Core #5)
The frequencies on the cores vary, they are alwys flipping between ~800MHz and then showing something like 2000-4000MHz.
The total utilization is never above 10%
I also noticed that voltages VID #0 - VID #5 vary all the time between ~0.600V and ~1.340V.
Reset BIOS settings with F9 without any change.
...aaaand I solved it.
Blew forcefully into the fan air intake in the back, had a giant cloud of fine dust come out. Temperatures are now fine and the fan is almost inaudible.
In other words, I thought it was a software problem and it turned out to be bad cooling due to dust collection.
You should keep your NUC in a cleaner environment.
[Windows 11 is the new Vista]
