Hhmmm, sounds like the EC is not operating. This may be why this ES was being dumped.
So, I would suggest that you try to do a BIOS Update. Use the latest BIOS Recovery file and install using the BIOS Recovery method. If that works, you may then have to repeat the install using the F7 method to ensure that the EC gets its firmware updated. Processes are explained here: Intel NUC BIOS Update and Recovery Instructions for Aptio V BIOS Core.
Hope this helps,
Power off. Then power on holding the power button down for a full 3 seconds or until LED flashes/changes color.
Hello JagaurMS
Thank you for posting on the Intel️® Communities.
I am glad to see fellow community members have helped you with this issue. We understand you have opened a web ticket support case with us, and we will continue to help you through that channel now. We will therefore close his community case. Please, keep in mind that this thread will no longer be monitored by Intel.
Thanks for your understanding.
Hugo O.
