I´m doing an app where we need to run a software that will show JS slideshows on a local IIS. We need this for quite a few locations..
My question is, what would be the minimum requirements for the NUC to be able to run this slideshow smoothly?
http://layerslider.kreaturamedia.com
I need to decide what NUC to get, it will be running windows 10.. but as of now, I dont know which one to get, that will be powerfull enough to run that slideshow smoothly?
The above slideshow will be the most demanding we would run..
Like to buy the cheaper i3, but have no idea if it can run it..
Hopefully someone here can help.
Thank you very much
Hello asteinmetz,
I understand that you are looking for the best-performance Nuc regarding the software you have mentioned.
Regarding this, in order to find the best Nuc that can run the software smoothly I will need to know the specifications or the different requirements that the software requires, for example:
David V
Hello asteinmetz,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
