Intel® Optane™ Memory
Error: 0xA007000B
JBrus1
got this error when it try to enable optane memory.
What does that mean?
Jack
Hello Jack,
We have two quick questions before getting started:
- Are you receiving a 0xA007000B, or 0xA0070008 error code?
- Did the error display a message as well, or only the code?
We look forward to hearing back from you.
Carlos A.
JBrus1
it´s 0xA007000B and code is not listed in common error codes discription.
Error message says that there was a problem with the intel optane application und that i´ll get help at intel.com/support/optane-memory
Error message in Intel optane log:
ERROR2017-06-21 08:17:13 – Error enabling optane
Utils.Exceptions.MiddlewareException: Error code: 0xA007000B
at MWClient.Actions.MwAction.b__4_0()
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
Jack
Hello jefferson2017,
I see, just wanted to confirm that it wasn't a typo. We'll go ahead and look into this error code, but first we'll need the following:
1. The https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility report from your computer.
2. A screenshot of your Disk Management utility showing your setup.
3. Your Optane™ log file.
To enable attachments you will need to switch over to the "advanced editor" mode while replying.
Carlos A.
JBrus1
did a clean install- Everything is working as expected again.
We're glad to hear that your issue has been resolved.
Did you clean install the Optane™ Memory software, or your OS?
Carlos A.
JBrus1
i did a clean install of the OS.
As it was upgraded from version to version form windows 7 to 8 to 8.1 to 10 i thought that it might be better to clean all the old stuff out and start from zero.
With clean OS, there was no problem with installing the optane drive. And somehow it operates faster than before.
Bye
Jack
Hello Jack,
Thanks for replying. I had assumed you were referring to the OS, but figured the extra information might be helpful to future users reading this thread.
If you need any further assistance, feel free to contact us again.
Carlos A.
