Intel® Optane™ Memory
1396 Discussions
Every time I click on a file the notification "Intel Optane(tm) Memory Pinning Unable to load DLL" comes up. Could someone explain what is wrong and how to fix it?
LH0001
This is the notification: https://imgur.com/a/tlSPHLo
Everything appears to work fine. It's just the notification keeps popping up.
LeonWaksman
  1. This is caused by Windows 10 1903 update.
  2. To fix this click on Windows key + x.
  3. Click on Apps and Features.
  4. Select "Optane Memory Extension" (on the right pane) and uninstall it.
  5. Read this for additional help https://www.intel.com/content/www/us/en/support/articles/000030517/memory-and-storage.html
Leon
LH0001
Thank you for the help. I thought that was the issue. I went back to the old windows will that be a problem when uninstalling Optane Memory Extension?
I know this probably isn't the right place to ask this but it order to stop the notification I turned off file explorer notifications by right clicking and disabling them in the notifications. I can't work out how to turn them back on now as in the notification settings there is no option to turn File Explorer notifications on.
LeonWaksman
  1. How to enable/disable File Explorer notification: https://www.howtogeek.com/267369/how-to-disable-notifications-in-windows-file-explorer/
  2. I suggest you to update your Windows again and uninstall the Optane Memory Extension.
Leon
