Intel® Optane™ Memory
1391 Discussions
Hi, I would like to know if it is possible to mount two intel optanas to support two different hard drives, since my motherboard has two nvme m2 ports, thanks.
gpapp6
LeonWaksman
System acceleration is only supported with one module and one supported drive. Additional modules in the system aren't supported for system acceleration.
Leon
LeonWaksman
Leon
n_scott_pearson
...But you could install a super fast M.2 NVMe SSD in the first M.2 connector and the Optane module in the second M.2 connector. This way, you get a super fast NVMe SSD for your system and boot files and an accelerated SATA HDD/SSD/SSHD for your data files. The best of both worlds! 😍
Hope this helps,
gpapp6
Thank you I will certainly do so
