Intel® Optane™ Memory
1391 Discussions
Hi. Is it possible to install Windows 32bit on a laptop with an HDD and the Intel Optane Memory? If yes, please tell me how. Thanks.
MCB
VARADHARAJAN
Valued Contributor II
MCB
Hi and thanks for the link, was helpful.
Tried again and I succeeded.
It's a laptop running Windows 10 64bit on HDD with Optane Memory.
I'm aware that Windows 10 32bit and the Legacy Bios are not supported by this technology. I's fine and I just need to run that OS version.
Here what I did to do the job, that may help other people.
  • disabeled Optane Memory within the Intel RST app and rebooted the PC (necessary step and that's why I couldn't install the OS at the first day because I didn't disable it).
  • removed that RST app and all related apps (IDK if this was necessary or not)
  • entered the BIOS and enabled the Legacy Bios mode and ran the OS setup as usual, done.
VARADHARAJAN
problems solved means , mark as answered , and close the case .If you dont require any further assisatnace
Good luck
MCB
Can't find the options. Can you please show me how? Thanks.
