Intel® Optane™ Memory
1402 Discussions
How to remove my disk as Intel Recovery Volume?
JSala24
I would like to remove my HDD as Intel Recovery Volume. How?
Currently my HDD is set as 'Current Read-Only State 'Yes from Disk Part.
Was able to make Disk Cache to No but eventually it returns back.
Could not open POST as well. CTRL key + I does not work.
Santiago_A_Intel
Hi JSala24
Thank you for contacting Intel® SSD support group.
In order to process your request properly, we will require your cooperation to get the necessary information to diagnose your unit.
Please indicate the kind of product you are requesting support for.
If it’s a SSD, you might proceed according to the following procedure and provide us with the following information:
•  SSU logs.
1-    Go to https://downloadcenter.intel.com/download/25293/
2-    Download the software.
3-    When finished downloading it, open it
4-    Please attach the SSU Log file obtained to your reply.
•  Please send us a screenshot of the “Disk Management” of windows showing all your HDDs and partitions.
•  Please send us the S.M.A.R.T. details.CSV file (SMART logs) from your Intel® SSD
It can be extracted by using the Intel® Solid State Drive Toolbox, as explained in the “IntelSolidStateDriveToolboxUserGuide.pdf”
(Please follow link below to download the guide)
https://www.intel.com/content/www/us/en/support/articles/000020382/memory-and-storage.html
On section 3.2 you can find the instructions on how to get this file.
Please follow this link to download SSD Toolbox
https://downloadcenter.intel.com/download/28593/Intel-Solid-State-Drive-Toolbox
We will be looking forward to your reply including this information.
Santiago A.
Under Contract to Intel Corporation
Santiago_A_Intel
Hi JSala24, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Santiago A. Intel® Customer Support Technician Under Contract to Intel Corporation
