Intel® Optane™ Memory
1391 Discussions
I bought an intel optane memory, but my PC does not have a native M.2 port for Optane, how can I install it?
AlHill
Hello Alex23,
Thank you for your interest in the Intel® Optane™ Memory.
When you say that your motherboard does not have a "native M.2 port for Optane", do you mean that your motherboard does not have a M.2 port at all? Or that it is not an Intel Optane memory ready motherboard (https://www.intel.com/content/www/us/en/architecture-and-technology/optane-memory-ready-boards-where-to-buy.html https://www.intel.com/content/www/us/en/architecture-and-technology/optane-memory-ready-boards-where-to-buy.html)?
Please attach the report generated by the Intel® System Support Utility for Windows* (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-).
Additionally, please check the links kindly provided by community member a.hill to make sure that your system meets the base requirements.
I'll be waiting for your response.
Andres V.
All requirements are met but the motherboard has no M.2 port. My PC is an HP Prodesk 400 G4. Can I use a generic adapter pcie x4 to m.2 nvme?
AlHill
If you have no M2 port, then all requirements are not met.
Did you read the documents from the links I attached?
What operating system?
Did you run the System Support Utility?
Doc
Yes, I read them.
Also in the manual says as requirement " M.2 type 2280 connector on a PHC Remapped PCIe controller and lanes in a x2 or x4 configuration with B or M keys that meet NVMe Spec 1.1"
The OS is Win 10 x64 Pro
I didn't run the utility because my PC is new HP ProdDesk 400 G4 and for now don´t turn On it. First i want install de module
http://www8.hp.com/co/es/products/desktops/product-detail.html?oid=16411597 PC de factor de forma reducido HP ProDesk 400 G4 (ENERGY STAR)(1KC20LT)| HP® Colombia
Hello Alex23,
Thank you for the clarification.
Using a PCIe x4 to M.2 adapter is not a tested and validated configuration, which means that we cannot guarantee that the module will work as expected.
We checked the link that you shared and even though it seems that your system meets most of the base requirements, an Intel Optane memory ready UEFI BIOS is required:
Since your system is not on the list of Intel Optane memory ready motherboards, our suggestion is to contact your system's manufacturer (https://support.hp.com/co-es/ https://support.hp.com/co-es/) and ask if your system has an Intel Optane memory ready UEFI BIOS.
Andres V.
