Intel® Optane™ Memory
1401 Discussions
Intel Optane Application bug?
I was trying to install my optane but an error occured. I tried to click "Open Event Viewer" but nothing shows up. Tried searching manually but not sure what I am suppose to look at.
Thank you.
My PC Spec:
Intel i7-700k
Gigabyte Z270 Gaming 7
Corsair 16GB 3000Mhz
240gb Crucial ssd (for booting)
32gb Intel Optane
2x1TB HDD
1x2TB HDD
Hello asyrawi,
Thanks for posting. We understand that you're experiencing issues with the Intel® Optane™ memory setup application.
In order to better assist you, please provide us with the Intel® Optane™ logs located at C:\Users\[your_user_name]\Intel\Logs.
If you haven't enabled the memory module yet, please test using the Intel® Rapid Storage Technology (Intel® RST) application instead. This tool can also enable Intel® Optane™ memory on your system.
The Intel® RST application can be https://downloadcenter.intel.com/download/27400/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=99743 downloaded here. Please use the file named "SetupRST.exe" and make sure you to uninstall the Intel® Optane™ memory setup application first .
Please let us know the results.
Eugenio F.
Hello asyrawi,
We haven't heard from you since the creation of the thread. Please let us know if there's anything else we can do for you.
Eugenio F.
