Intel® Optane™ Memory
1396 Discussions
Is my optane compatible with a laptop
FRahm2
I would like to know if the optane memory I have compatible with a laptop.
I am unable to see my optane memory in my bios and in windows after a couple a few hours of installing. It was working fine till then. The optanememory.exe even detected the memory.
However I was told that only m10 optane are compatible with laptops. Is this true?
laptop details: Lenovo yoga 520ikb
i3 8th gen
m.2 3x4 pcie slot
DiegoV_Intel
Hi FRahm2,
Thank you for posting in the Intel® communities.
I cannot confirm if your laptop model is compatible with the module. Only the laptop manufacturer, Lenovo* in this case, can confirm if your laptop is compatible or not.
You’re correct when saying that only the M10 models are compatible with laptops (once the laptop manufacturer confirm the compatibility). I search for the product code of your module and it’s a regular model (not M10), so it may be possible that the reason of failure is this, although you also have to confirm with your laptop manufacturer if your laptop model is indeed compatible with the module.
The main difference between the regular model and the M10 model is the power consumption. That’s why the regular models cannot be used in mobile devices like laptops, but the M10 model on the other hand has been designed specifically for this purpose so they improve the power management support allowing them to be included in laptops and Desktops too.
I hope this clarifies the concern.
If there is anything else I can help you with, please feel free to ask.
Have a nice day.
Diego V.
Under Contract to Intel Corporation
DiegoV_Intel
Hi FRahm2,
Have a nice day.
Diego V.
