Intel® Optane™ Memory
1401 Discussions
May I know how to setup the module for Optane Memory in RST application?
AChun11
DiegoV_Intel
Hi AChun11,
Which version of the Intel® RST do you have?
I recommend you to download the latest one from the following site. Please consider that you can also use the Intel® Optane™ Application to setup the module. Both applications work for this purpose.
Before installing one of the applications above, please uninstall first the one that you have to avoid issues.
Let me know if they work for you to setup the module.
Diego V.
Under Contract to Intel Corporation
DiegoV_Intel
Hi AChun11,
Thank you for posting in the Intel® communities.
If you are using the Intel® RST Application, there is a tab that says “Intel® Optane™ Memory” that is used to manage the module. In order to enable the module, you just have to click on the Enable button under the “Status” tab after the system has been properly configured (BIOS and OS).
Please check the following picture as reference and let me know if this clarifies your doubt.
Have a nice day.
Diego V.
AChun11
Currently i just had this status( Attached with Picture below) in my system, so i need to wait my Bios to update ? Thanks for reply.
DiegoV_Intel
Hi AChun11,
Diego V.
DiegoV_Intel
Hi AChun11,
I will be waiting for your updates.
On the other hand, if you were able to setup the module with either the Intel RST application or the Intel Optane application, please let me know.
Diego V.
AChun11
Yup, i already follow your steps, i uninstalled the RST application and install the Optane memory, Its works! Thank you so much Diego V.
DiegoV_Intel
Hi AChun11,
It’s great the Intel® Optane™ Memory is setup and working in your system.
Thank you for the confirmation. If you ever have another issue or concern related to the module, please don’t hesitate to open a new thread. We’ll try to help you in any way possible.
Have a nice day.
Diego V.
