Intel® Optane™ Memory
1401 Discussions
No Compatible Disks for Intel Optane Memory
wv799
I tried to install the rst software but it doesn't give much feedback. Then I downloaded setupoptanememory.zip and this one gives me: No Compatible Disks for Intel Optane Memory.
I have attached some information about my pc. Please tell me if I need to provide further detail.
LeonWaksman
Hi @wv799
1. Although you have installed Optane memory on your MSI board, it is not recognized yet in Windows. I don't see your BIOS, so I can't see if it is recognized there.
2. I assume that you are intending to accelerate with Optane your Toshiba 3 GB data drive. I suggest that you try the following:
3. Open the Disk Management and shrink the partition leaving 5 -15 MB of unallocated space in this drive end (after partition). This unallocated space will be used by Optane.
4. Update the RST driver. Download Intel RST Driver and unzip it on your drive. Right click on iaStorAC.inf and select install from drop down menu. Reboot your computer.
5. Follow MSI Pro Cast#14 –Intel® Optane™ Memory Tutorial to set BIOS setting and enable Optane.
Leon
wv799
to prove I do have an optane
AlHill
If you do not have optane, then why are you downloading and installing RST in the first place?
Set you bios to boot AHCI, save, and boot into SAFE MODE.   Then boot as you normally would.
wv799
Can you see my second attachment which is a photo stating I do have optane?
AlHill
Sorry,  I read it as you NOT having optane.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
wv799
I have it in my first attachment. Do you even read my description?
AlHill
I told you I misread your post, ok?
An Intel support engineer will be able to assist you.
wv799
That was about the report text file I attached at the very beginning. Basically you misread again after you realized you misread.
LeonWaksman
Hi @wv799
Leon
wv799
Thank you for your reply.
I couldn't detect the optane in my system, not in device manager, so I guesss it wouldn't show in BIOS either?
I shrinked the HDD and updated RST but after all it didn't work.
There wasn't much to do in BIOS since msi has made it very easy to simply click a button.
LeonWaksman
You should find the Optane memory in BIOS. Storage section, installed in M.2 slot. If you don't see it there, remove Optane from its slot and reseat  it again. You may also try to replace the slot with the System SSD and see if its helping. Any way you need to see Optane first recognized in BIOS and Windows.
Leon
AlHill
@wv799 Good luck with your project.
