- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Source:RST Middleware
Event ID: 7002
Level: Warning"
Please someone help me out
- Etiquetas:
- 7002
- BIOS
- Memory
- RST
- RST Middleware
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
These S.M.A.R.T. events are indications - from the drive itself - of a pending failure. You should back up your data on this drive and replace it as soon as possible.
Now, there is the possibility of false-positive notifications via RST. To be sure, do the following:
- Make a backup of all data on the drive, just to be sure.
- Stop the caching of drive operations via the Optane module.
- Use a tool - best if from the drive manufacturer - that displays the S.M.A.R.T. status and attributes for the drive.
- If the S.M.A.R.T. status indicates an ongoing error or there is a S.M.A.R.T. attribute whose current value is indicating a problem, then do replace the drive immediately (if still in warranty period, call WD to have it replaced).
Hope this helps,
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hope this helps,
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Should I remove it from my pc?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
when I look at Event Viewer there is a certain error that concerns me...
Disk is starting to degrade. New SMART event detected.
why would my drive be degrading if this is a new pc?
Disk model: SAMSUNG MZVLQ1T0HBLB-00BH1
Disk serial: S673NJ0T235283
event id 7002
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello, FaizanRaza.
In this particular case, it would be better to use the tools provided by the HDD manufacturer (WD) to review its status or consult the manufacturer directly, as n_scott_pearson mentioned.
That way you can confirm if this SMART event is critical and a replacement is required, making use of the manufacturer's warranty if applicable.
Thank you for marking the thread as resolved, it will be closed on December 2nd if there is no confirmation about further assistance being required.
Bruce C.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
event id 7002
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
@ARPANET Do not triple post. Contact samsung for support with your samsung drive.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
@ARPANET Quaddruple posting is very bad. Contact samsung for support of your samsung drive.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
