Intel® Optane™ Memory
1401 Discussions
Problem pinning applications using the 'Intel Optane Memory and Storage Management; app.
BMoly
I have been having problems pinning certain applications using the Optane app. They would generate a file access error in the app.
Intel customer support couldn't help, but I managed to work out that if the executable extension was capitalised, then it wouldn't pin. If I changed it to lower case it would!
So WINWORD.EXE doesn't pin, but WINWORD.exe does. Crazy.
Thanks Intel!
JosafathB_Intel
Hello BMoly,
Thank you for contacting Intel Technical Support.
We noticed that you have an open case with our advanced technical support department that is related to the same topic. We will continue to provide you with support in your open case.
Thank you for your patience and understanding.
Josh B.
A Contingent Worker at Intel
JosafathB_Intel
Hello BMoly,
Josh B.
