Intel® Optane™ Memory
Comunicados
1398 Discussões
To install Intel optane memory requires delete intel rapid, if will delete it nothing happens with data stored on a disk, right?
VT0001
Principiante
2.408 Visualizações
1 Solução
DiegoV_Intel
Moderador
2.032 Visualizações
Hi VT0001,
Thank you for posting in the Intel® communities.
Actually, you can use the Intel® RST Application to setup the module, so there is no need to un-install it because you can also use this application for the module.
If you prefer, on the other hand, to use the Intel® Optane™ Application, you will indeed require to un-install the Intel® RST Application first. In this case, you can proceed to un-install it without worries about your data in your drives.
I hope this information clarifies your concern.
If you have additional doubts about the Intel® Optane™ Memory setup, feel free to ask.
Have a nice day.
Diego V.
Under Contract to Intel Corporation
Ver solução na publicação original
1 Responder
DiegoV_Intel
Moderador
2.033 Visualizações
Hi VT0001,
Have a nice day.
Diego V.
Responder
