Intel® Optane™ Memory
1391 Discussions
Why is my optane memory not being detected at all
ASamu3
I am using HP pavilion gaming. I have issues with the os so I formated the hard drive and reinstalled the windows. The issue now is that my optane memory is not showing in the Intel rapid storage technology, and is not showing on my bios. I have read similar complains but no solution works. My optane isn't showing in my bios and I have tried cleaning it with command prompt but my hard disk is the only thing showing. I need help.
n_scott_pearson
Did you disable the Optane Memory module before you performed this Windows reinstall? If the Optane Memory module is still enabled, you aren't going to see it separately.
AlHill
Contact HP regarding your bios and its support of Optane.
Doc
n_scott_pearson
