Intel® Optane™ Memory
1392 Discussions
hola, tengo dos memorias Intel Optane puedo utilizar las dos para aceleración de disco cada una con un disco diferente?
AVazq3
DiegoV_Intel
Hi AVazq3,
Thank you for posting in the Intel® communities.
Only one Intel® Optane™ Memory can be used in a single system, so considering the scenario you are mentioning, it would not be possible to use the 2 modules to accelerate 2 different drives in the same system.
You can only accelerate one drive with one module.
I hope this information answered your concern.
If there is anything else I can help you with, feel free to ask.
Note: Communities support is only provided in English.
Have a nice day.
Diego V.
Under Contract to Intel Corporation
DiegoV_Intel
Hi AVazq3,
Have a nice day.
Diego V.
AVazq3
Ty men, one more question can I use one optane with the OS instaled and the other for accelerating?
DiegoV_Intel
Hi AVazq3,
The Intel® Optane™ Memory is a module designed to accelerate a SATA drive. This SATA drive could be the primary drive where the OS is installed, or a secondary drive. This means that you don’t have to install the OS in the Intel® Optane™ Memory, but in the SATA drive and then you can accelerate that drive.
As only one Intel® Optane™ Memory is supported, it’s not possible to have 2 or more modules, so you will be able to accelerate only one drive.
I hope this information clarifies the inquiry.
Let me know if there is anything else I can help you with.
Have a nice day.
Diego V.
DiegoV_Intel
Hi AVazq3,
I would like to know if there is anything else I can help you with, or if the information above answered your concerns.
Diego V.
