I have a blank screen on the 8th generation
You are in the wrong forum.
So the Intel customer support technicians can have more information about your system, download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Success breeds complacency. Complacency breeds failure. (Andy Grove)]
