Intel® Optane™ Persistent Memory
Examine Issues Related to Intel® Optane™ Persistent Memory
103 Discussions
Can Intel TME work with Intel Optane Persistent Memory?
Aoyang-Tong
Currently, I'm using an Intel(R) Xeon(R) Gold 6330 CPU @ 2.00GHz with Intel Optane Persistent Memory 200 Series in App Direct Mode. I have noticed that the Total Memory Encryption (TME) is supported in the 3rd generation Intel Xeon Scalable Processors. So, I would like to know if Intel TME can work with Intel Optane Persistent Memory?
B_Y
Hi @Aoyang-Tong,
Thank you for your patience. After further check, Intel TME is not compatible with Intel Optane PMem. If Intel TME is enabled, Intel Optane PMem will be disabled.
I hope this clarifies your question. Do let us know if you need any further assistance.
BY_Intel
Intel Customer Support
B_Y
Hi @Aoyang-Tong,
Thank you for posting in Intel Optane Memory Communities.
Please give us some time to check internally and respond adequately to your question about Total Memory Encryption (TME) and Intel Optane Persistent Memory compatibility.
May I also seek your help to advise following information:
1. OS build version
2. Model of motherboard
Thank you.
BY_Intel
Aoyang-Tong
Hi, B_Y,
Currently, I'm using Ubuntu 18.04.1 and an Intel(R) Xeon(R) Gold 6330 CPU @ 2.00GHz with Intel Optane Persistent Memory 200 Series in App Direct Mode. And I would like to know if Intel TME can work with Intel Optane Persistent Memory?
B_Y
Hi @Aoyang-Tong,
Thank you for sharing the OS version. Can you advise if you are using own system board/ motherboard? Or using specific model original equipment manufacturer(OEM) system board/ motherboard?
Thank you.
BY_Intel
Aoyang-Tong
Hi, B_Y,
The system board/motherboard I'm using is SITONHOLY IW2221-2GR and the OS version is Ubuntu 18.04.1.
B_Y
Hi @Aoyang-Tong,
Please allow us some time to review and respond to your inquiry. Thank you for your understanding.
BY_Intel
B_Y
Hi @Aoyang-Tong,
BY_Intel
Aoyang-Tong
Hi, B_Y,
Thank you very much for your reply. It's clear to me now.
B_Y
Hi @Aoyang-Tong,
Please be informed that we will now close this request since we have provided the resolution. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you.
BY_Intel
