Intel® Optane™ Persistent Memory
Examine Issues Related to Intel® Optane™ Persistent Memory
Mixing part number?
Yitpong
If I have a set of NMA1XBD256GQS running in Memory Mode... Can I mix them with another set of NMA1XXD256GPS?
Both NMA1XBD256GQS & NMA1XXD256GPS are Optane-100 256GB modules.
Thanks!
SteveScargall
If these modules are installed in an OEM/ODM production server under a support contract, you should check with your hardware support vendor as they are unlikely to support or replace the 'GQS' parts should one fail.
The two parts are compatible. The 'GQS' modules are pre-production samples, whereas 'GPS' are production quality. It is recommended to have the same firmware version across all PMem modules in the host.
SteveScargall
Yitpong
I'm replying here to confirm them running on firmware v1.0.2.5444.
Thanks Steve!
