Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
489 Discussions
Pls help Provide Thermal Model of Optane SSD P5800X
WilsonChien
Hi  intel
I am evaluating the thermal analysis of a P5800X SSD on a 4U server. Pls help Provide Thermal Model of Optane SSD P5800X( Flotherm model).
BrusC_Intel
Hello, WilsonChien.
Good day,
Thank you for posting on the Intel Community Support Forums.
I received your case regarding the thermal model of the P5800X, I will be glad to assist you.
This type of information is not publicly available, and for us to confirm if this can be provided, there must be an active NDA with you or your company, so please let me know the following.
Have you requested this type of information in the past?
If that is the case, I would recommend using the same support channel used the last time to request it, for example, if you used the IPS portal.
If you have an active NDA, please let me know, but do not provide it here, and we will continue via e-mail.
I will follow up on November 4th in case additional time is required.
Bruce C.
WilsonChien
Hello , Bruce C:
      I have posted the question on IPS (#00657362), thank you for your help!
BrusC_Intel
Hello, WilsonChien.
Thank you for letting us know.
The thread will be closed right now, but if you require any type of assistance from Intel in the future, you can always contact us back.
I hope you get the information as soon as possible.
Bruce C.
