Hellow.
"SSD Data Center tools" do not see the SSD drive. (tried 3.0.4 and 3.0.7)
SSD DS S3520 firmware N2010112.
Tried ESXi 5.5 U1 and 6.5.
I have two servers based on motherboards ASUS P9D-M with chipset C224 with LSI® MegaRAID on board (no RAID in AHCI mode) and "server" ASUS on H67-V (in AHCI mode).
I did everything in accordance with the documentation.
- SSDs are connected to the SATA port directly. AHCI mode. (no RAID)
- VIB installed
Try:
/ opt / intel / isdct # ./isdct show -intelssd
And all the time i see the same thing: - "No results"
What did I miss?
~ # esxcli storage core device list
t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
Display Name: Local ATA Disk (t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__)
Has Settable Display Name: true
Device Type: Direct-Access
Multipath Plugin: NMP
Devfs Path: /vmfs/devices/disks/t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
Vendor: ATA
Model: INTEL SSDSC2BB48
Revision: N201
SCSI Level: 5
Is Pseudo: false
Status: on
Is RDM Capable: false
Is Local: true
Is Removable: false
Is SSD: true
Is Offline: false
Is Perennially Reserved: false
Queue Full Sample Size: 0
Queue Full Threshold: 0
Thin Provisioning Status: yes
Attached Filters:
VAAI Status: unknown
Other UIDs: vml.010000000050484456373337313038303034383042474e2020494e54454c20
Is Local SAS Device: false
Is Boot USB Device: false
No of outstanding IOs with competing worlds: 32
~ # esxcli storage core path list
sata.vmhba0-sata.0:0-t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
UID: sata.vmhba0-sata.0:0-t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
Runtime Name: vmhba0:C0:T0:L0
Device: t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__
Device Display Name: Local ATA Disk (t10.ATA_____INTEL_SSDSC2BB480G7_____________________PHDV73710800480BGN__)
Adapter: vmhba0
Channel: 0
Target: 0
LUN: 0
Plugin: NMP
State: active
Transport: sata
Adapter Identifier: sata.vmhba0
Target Identifier: sata.0:0
Adapter Transport Details: Unavailable or path is unclaimed
Target Transport Details: Unavailable or path is unclaimed
Maximum IO Size: 33553920
- « Previous
- 1
- 2
- Next »
Here you go
16:22:55:582462 [debug] tdk_interface_dll.cpp(262) SendXMLMessage: Entering
16:22:55:584462 [debug] TDKInterface.cpp(522) scan: Entering
16:22:55:584480 [debug] DeviceFinder_NVME.cpp(63) scan: Entering
16:22:55:584490 [debug] DeviceFinder_NVME.cpp(100) scanPhysicalDevices: Entering
16:22:55:584597 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:584621 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme0
16:22:55:584674 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:584688 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme1
16:22:55:584724 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:584736 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme2
16:22:55:584770 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:584782 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme3
16:22:55:584815 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:584827 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme4
16:22:55:584859 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:584871 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme5
16:22:55:584903 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:584915 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme6
16:22:55:584947 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:584959 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme7
16:22:55:584991 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585003 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme8
16:22:55:585035 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585047 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme9
16:22:55:585079 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585091 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme10
16:22:55:585124 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585135 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme11
16:22:55:585168 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585180 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme12
16:22:55:585212 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585224 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme13
16:22:55:585256 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585268 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme14
16:22:55:585300 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585312 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme15
16:22:55:585344 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585356 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme16
16:22:55:585388 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585400 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme17
16:22:55:585432 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585444 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme18
16:22:55:585476 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585487 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme19
16:22:55:585520 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585532 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme20
16:22:55:585564 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585575 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme21
16:22:55:585607 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585619 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme22
16:22:55:585651 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585662 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme23
16:22:55:585695 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585706 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme24
16:22:55:585738 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585750 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme25
16:22:55:585782 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585794 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme26
16:22:55:585826 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585838 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme27
16:22:55:585870 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585882 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme28
16:22:55:585914 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585925 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme29
16:22:55:585958 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:585969 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme30
16:22:55:586001 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:586013 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme31
16:22:55:586045 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:586056 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme32
16:22:55:586089 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:586101 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme33
16:22:55:586133 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:586145 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme34
16:22:55:586177 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:586189 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme35
16:22:55:586221 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:586233 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to connect to device. Ignoring intel-nvme36
16:22:55:586265 [error] Connection_Path.cpp(91) open: vmk_MgmtUserInit error: 19
16:22:55:586277 [error] DeviceFinder_NVME.cpp(134) scanPhysicalDevices: Failed to conne...
Hi Derek1234,
Thanks for the logs provided.
Could you please confirm if you installed the latest Intel® SSD Data Center Tool in a fresh installation of the VMware* ESXi?
Junior M.
Intel,
no it is not a fresh install of 6.5. This is a production server running live VM's I can't reinstall Vmware from scratch. But I do get the same behavior on 6.0 and 6.5 on R730XD servers. ( I do have a R720 that is running ESXi 6.0 and it recognizes just fine).
Derek
Hi Derek1234,
Thanks for the information.
We would investigate the situation with the logs provided. We will keep you posted with any updates.
Junior M.
Hi Sptta,
Could you please let us know if you were able to try with the fresh installation of the ESXI*?
Derek1234
We still investigating the logs you provided. We will keep you posted with any updates.
Junior M.
Hi Derek1234 Sptta,
We would like to let you know that as per Intel® SSD Data Center Tool https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/Intel_SSD_DCT_3_0_x_User_Guide.pdf user guide, section 1.2(system requirements). On ESXi* systems, the tool only works on Intel(R) PCIe NVMe* drives using the Intel(R) ESXi* NVMe* driver. That is why you are not able to see the SSDs with the commands.
Please let us know if there is something else we can assist you with.
Junior M.
- « Previous
- 1
- 2
- Next »
