Intel® Optimized AI Frameworks
Receive community support for questions related to PyTorch* and TensorFlow* frameworks.
90 Discussions
Can MKL_DNN used for NER model with a bert?
Hap_Zhang
I tried to use mkl-dnn accelerate the inference of NER(Named Entity Recognition) model, however, some errors happened:
dnnl_verbose,exec,cpu,reorder,simple:any,undef,src_f32::blocked:a:f0 dst_f32::blocked:a:f0,,,5,0.0090332
Traceback (most recent call last):
  File "bert_for_token_classification_example_fast_dnnmkl.py", line 161, in <module>
    torch_outputs_ = model_(input_ids_.to(device), attention_mask_.to(device), token_type_ids_.to(device))
  File "/opt/miniconda3/lib/python3.7/site-packages/torch/nn/modules/module.py", line 1051, in _call_impl
    return forward_call(*input, **kwargs)
  File "/opt/miniconda3/lib/python3.7/site-packages/transformers/models/bert/modeling_bert.py", line 1701, in forward
    return_dict=return_dict,
  File "/opt/miniconda3/lib/python3.7/site-packages/transformers/models/bert/modeling_bert.py", line 944, in forward
    extended_attention_mask: torch.Tensor = self.get_extended_attention_mask(attention_mask, input_shape, device)
  File "/opt/miniconda3/lib/python3.7/site-packages/transformers/modeling_utils.py", line 289, in get_extended_attention_mask
    extended_attention_mask = attention_mask[:, None, None, :]
RuntimeError: opaque tensors do not have strides
I use the transformers(hugging face) with 4.6.1,  can someone help to point out the problem in it? Thanks a lot.
Gopika_Intel
Hi
We have not heard back you. As mentioned please try with the next release of ipex. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel
Gopika
Gopika_Intel
Thank you for posting in Intel Communities. We are trying to reproduce the issue from our end, we will get back to you as soon as we get an update.
Gopika
Gopika_Intel
Could you please give us the following information so that we can try reproducing the issue from our end?
1. The pytorch version
2. Whether you are using quantized model or not
3. Steps to reproduce the issue
4. The model you are using
Gopika
Hap_Zhang
Hi, Gopika,
thank you for your reply!
Reply:The pytorch version is 1.9.0
Reply:not quantized model, just a model finetuned in BERT-Base, Chinese
Reply:
device = torch.device("cpu")
model_id = "bert-base-chinese"
config = PretrainedConfig.from_pretrained(model_id)
config.num_labels = 5
model = BertForTokenClassification.from_pretrained(model_id, config=config).to(device)
model.load_state_dict(torch.load("model-epoch49.pt", map_location=torch.device(device)))
model.eval()
tokenizer = BertTokenizer.from_pretrained(model_id)
sentence = "海底捞"
result = tokenizer(sentence, padding='max_length', max_length=512, truncation=True, return_tensors='pt').data
input_ids, token_type_ids, attention_mask = result.get('input_ids'), result.get('token_type_ids'), result.get('attention_mask')
input_ids_ = input_ids.float().to_mkldnn()
token_type_ids_ = token_type_ids.float().to_mkldnn()
attention_mask_ = attention_mask.float().to_mkldnn()
model_ = mkldnn.to_mkldnn(model)
torch_outputs = torch_outputs_.to_dense()
Reply:The "model-epoch49.pt" is 388M and exceed the maximum limit, so i can not attach here
Gopika_Intel
The problem is that the opaque tensors do not have strides and it is not supported by the current version of ipex. Please try with the next release of ipex. Please refer: https://github.com/intel/intel-extension-for-pytorch for more information on ipex.
Gopika
Gopika_Intel
Has the solution provided helped? Please let us know whether your query is resolved.
Gopika
Gopika_Intel
Hi
Gopika
