Intel® Optimized AI Frameworks
Receive community support for questions related to PyTorch* and TensorFlow* frameworks.
93 Discussions
Distribute XGBoost on multiple nodes
Misra
Does Intel's distribution of XGBoost (in the oneAPI AI Analytics Toolkit) support multi-node training? If so, can this experiment be executed on Devcloud? Is there any reference documentation available?
Manjari
JananiC_Intel
Thanks for posting in Intel forum.
We will check on this and get back to you soon.
For your information, currently we don't have any reference documentation for Intel XGBoost multi node training, we will let you know once we get an update regarding this.
Janani Chandran
JananiC_Intel
For multi-node training with Intel XGBoost in DevCloud follow the steps mentioned in the below article.
https://medium.com/intel-analytics-software/distributed-xgboost-with-modin-on-ray-fc17edef7720
In DevCloud, multi-node computation is only available through the job queue.
Syntax for multi-node:
qsub -l nodes=<count>:ppn=2
You can combine a request for multiple nodes with a request for their specific features.
Try this and let us know the updates.
Janani Chandran
mmisra18
JananiC_Intel
Is your issue resolved? Do you have any update?
Janani Chandran
Misra
Thank you for your reply. I did try this method before. However, when I looked into OneAPI and DevCloud documentation, it mentioned that in order to distribute XGBoost training between multiple nodes I would have to use MPI communication for nodes to process in parallel.
I am unable to find documentation or any code sample that would explain it since I have no experience in MPI application programming.
Could you please let me know more about it? If this is the correct way or the way you mentioned is same as the above.
Thank you!
Manjari Misra
AthiraM_Intel
Please find the below documentation for running basic mpi application in DevCloud.
You can find the sample code under "Distributed-Memory Architecture" topic.
link: https://devcloud.intel.com/oneapi/documentation/advanced-queue/
Hope this helps.
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
