Intel® Optimized AI Frameworks
Receive community support for questions related to PyTorch* and TensorFlow* frameworks.
94 Discussions
Pytorch for Intel on Intel(R) UHD Graphics
jmoyniham
I am trying to conduct language model inference using a computer that has an Intel processor. I have loading pytorch for Intel (along with the Intel Driver and DeepLearning tools) following torch and intel instructions:
Getting Started on Intel GPU — PyTorch 2.6 documentation
PyTorch Prerequisites for Intel® GPUs
This is the processor on my computer:
13th Gen Intel(R) Core(TM) i5-1335U, 1300 Mhz, 10 Core(s), 12 Logical Processor(s)
I run this script:
import torch
import intel_extension_for_pytorch
import logging
import platform
def load_device(model: torch.nn.Module):
logging.info(f"CUDA available: {torch.cuda.is_available()}")
if torch.cuda.is_available():
logging.info(f"CUDA version: {torch.version.cuda}")
device = torch.device("cuda")
elif platform.system() == "Darwin" and torch.backends.mps.is_available():
logging.info("MPS Metal available")
device = torch.device("mps")
elif hasattr(torch, 'xpu') and torch.xpu.is_available():
logging.info("Intel XPU available")
device = torch.device("xpu")
else:
device = torch.device("cpu")
logging.info(f"Using device {device}.")
model.to(device)
return device, model
My log then states that is "Using device xpu". This leaves me to assume that the issue is not with pytorch of my processor. Is this a correct assumption?
The error arises when I load the model + device to my masked language modeling inference code. I routinely receive some form of runtime error, such as:
Traceback (most recent call last):
File "C:\Users\jm9095\logion-app\src\backend\main.py", line 181, in prediction_endpoint
results = predict.prediction_function(
text,
...<5 lines>...
num_predictions=5,
File "C:\Users\jm9095\logion-app\src\backend\prediction\predict.py", line 59, in prediction_function
outputs = model(**chunk_inputs)
File "C:\Users\jm9095\AppData\Local\Programs\Python\Python313\Lib\site-packages\torch\nn\modules\module.py", line 1739, in _wrapped_call_impl
return self._call_impl(*args, **kwargs)
File "C:\Users\jm9095\AppData\Local\Programs\Python\Python313\Lib\site-packages\torch\nn\modules\module.py", line 1750, in _call_impl
return forward_call(*args, **kwargs)
File "C:\Users\jm9095\AppData\Local\Programs\Python\Python313\Lib\site-packages\transformers\models\bert\modeling_bert.py", line 1461, in forward
outputs = self.bert(
input_ids,
...<9 lines>...
return_dict=return_dict,
File "C:\Users\jm9095\AppData\Local\Programs\Python\Python313\Lib\site-packages\transformers\models\bert\modeling_bert.py", line 1108, in forward
extended_attention_mask = _prepare_4d_attention_mask_for_sdpa(
attention_mask, embedding_output.dtype, tgt_len=seq_length
File "C:\Users\jm9095\AppData\Local\Programs\Python\Python313\Lib\site-packages\transformers\modeling_attn_mask_utils.py", line 448, in _prepare_4d_attention_mask_for_sdpa
if not is_tracing and torch.all(mask == 1):
RuntimeError: Native API failed. Native API returns: 20 (UR_RESULT_ERROR_DEVICE_LOST)
Or I most recently encountered this error without making any changes to my code or system:
text,
...<5 lines>...
num_predictions=5,
File "C:\Users\jm9095\logion-app\src\backend\prediction\predict.py", line 74, in prediction_function
predicted_index = int(sorted_idx[k].item())
RuntimeError: Native API failed. Native API returns: 2147483646 (UR_RESULT_ERROR_UNKNOWN)
I wondered whether the issue is because of the Intel driver, as I do not encounter this problem with other graphics processors (e.g. Nvidia, M-chip) or when using my PC's CPUs. That is, the issue only arises when trying to load the xpu device. But given that pytorch does load the xpu device, I do not know whether this is correct. If not, might anyone be able to help me in troubleshooting what may be the cause of the problem?
Labels (3)
DhannielM_Intel
Hi jmoyniham,
Thank you for posting in the community. It appears you're experiencing issues with initiating the device for use at the start of your program. Could you please provide the exact model of your laptop and the amount of RAM it currently has? Additionally, are you running this program directly on your system, or are you using a third-party platform like Google Colab, Kaggle, etc.?
Dhanniel M.
jmoyniham
Thank you for your response @DhannielM_Intel.
I am running this directly on my system.
I am using  a Dell Latitude 5540 x64 with Windows 11 Enterprise. 16GB RAM. The processor is:
13th Gen Intel(R) Core(TM) i5-1335U, 1300 Mhz, 10 Core(s), 12 Logical Processor(s).
RandyT_Intel
Hello @jmoyniham ,
Have you tried contacting Dell regarding this concern? They usually have specific steps to address this issue using their own technologies. However, let me coordinate this internally to see if we can find something that might help address this error message. I'll post an update here or notify you directly once there are any developments. If I need further details, I'll reach out to you here. I appreciate your patience as I work on this matter.
Randy T.
jmoyniham
@RandyT_IntelThank you for looking into this.
Dell advised reaching out to Intel
RandyT_Intel
Hello @jmoyniham ,
I wanted to provide you with an update regarding your recent case with us.
After a thorough review by our specialist, it has been determined that your case would be best addressed by our Intel® Optimized AI Frameworks. To ensure you receive the most accurate and efficient support, we will be rerouting your case to the appropriate forum.
Please rest assured that this transition will be handled smoothly, and you will receive the necessary guidance and assistance from the experts in the Intel® Optimized AI Frameworks team.
Thank you for your understanding and cooperation.
Randy T.
wangk2
@jmoyniham
Thanks for raising the ticket. Please refer to the hardware requirements for Intel GPU support in PyTorch: https://pytorch.org/docs/main/notes/get_start_xpu.html#hardware-prerequisite. And you can refer to https://pytorch-extension.intel.com/installation?platform=gpu&version=v2.6.10%2Bxpu&os=windows&package=pip for the detailed SKUs that have been verified. The product series you are using is not in our support list. We would recommend upgrading to the hardware that we've listed to leverage our PyTorch support and optimizations. Thanks.
Best,
Kai
Intel AI Framework Technical Support Team
jmoyniham
@RandyT_Inteland @wangk2 Thank you very much for your help
