Intel® Optimized AI Frameworks
Receive community support for questions related to PyTorch* and TensorFlow* frameworks.
94 Discussions
lib conflict running https://github.com/ucbdrive/few-shot-object-detection on macbook
Jon_Barker
Here's the error, any ideas?
(fsdet) jonbrkr@iad12-dhcp-142-207-122 few-shot-object-detection % python3 -m demo.demo --config-file configs/COCO-detection/faster_rcnn_R_101_FPN_ft_all_1shot.yaml \
--input portraitjpg.jpg --opts MODEL.DEVICE cpu MODEL.WEIGHTS fsdet://coco/tfa_cos_1shot/model_final.pth
[11/18 06:54:51 detectron2]: Arguments: Namespace(confidence_threshold=0.5, config_file='configs/COCO-detection/faster_rcnn_R_101_FPN_ft_all_1shot.yaml', input=['portraitjpg.jpg'], opts=['MODEL.DEVICE', 'cpu', 'MODEL.WEIGHTS', 'fsdet://coco/tfa_cos_1shot/model_final.pth'], output=None, video_input=None, webcam=False)
froze backbone parameters
froze proposal generator parameters
froze roi_box_head parameters
[11/18 06:54:51 fvcore.common.checkpoint]: Loading checkpoint from fsdet://coco/tfa_cos_1shot/model_final.pth
[11/18 06:54:51 fvcore.common.file_io]: URL http://dl.yf.io/fs-det/models/coco/tfa_cos_1shot/model_final.pth cached in /Users/jonbrkr/.torch/fvcore_cache/fs-det/models/coco/tfa_cos_1shot/model_final.pth
OMP: Error #15: Initializing libiomp5.dylib, but found libiomp5.dylib already initialized.
OMP: Hint This means that multiple copies of the OpenMP runtime have been linked into the program. That is dangerous, since it can degrade performance or cause incorrect results. The best thing to do is to ensure that only a single OpenMP runtime is linked into the process, e.g. by avoiding static linking of the OpenMP runtime in any library. As an unsafe, unsupported, undocumented workaround you can set the environment variable KMP_DUPLICATE_LIB_OK=TRUE to allow the program to continue to execute, but that may cause crashes or silently produce incorrect results. For more information, please see http://www.intel.com/software/products/support/.
zsh: abort python3 -m demo.demo --config-file --input portraitjpg.jpg --opts cpu
/Users/jonbrkr/anaconda3/envs/fsdet/lib/python3.7/multiprocessing/semaphore_tracker.py:144: UserWarning: semaphore_tracker: There appear to be 1 leaked semaphores to clean up at shutdown
len(cache))
JananiC_Intel
Thanks for posting in Intel forums.
Could you confirm whether you are using any intel products in this workload?
Jon_Barker
Yes, I am running this on a macbook pro (2020 I believe) with this processor:
1.4 GHz Quad-Core Intel Core i5
JananiC_Intel
Thanks for the update.
We were asking about the intel software products or intel libraries.Are you using any of these in your workload?
Janani Chandran
JananiC_Intel
Could you provide us the previously asked details?
Janani Chandran
JananiC_Intel
I have not heard back from you .We won't be monitoring this issue.If you need further assistance ,please post a new thread.
Janani Chandran
