Intel® Optimized AI Frameworks
Receive community support for questions related to PyTorch* and TensorFlow* frameworks.
signed 8-bit * signed 8-bit VNNI
lin__chiungliang
I'm trying to use VNNI in my program.
I ran the sample code, which do MAC operation by _mm512_dpbusds_epi32,
I found that it's singed 8-bit and unsigned 8-bit operation
Does there any optimized instruction support
1. signed 8-bit and signed 8-bit MAC operation
2. unsigned 8-bit and unsigned 8-bit MAC operation
Lot of thanks
chiungliang
AthiraM_Intel
We are forwarding this case to technical experts.They will assist you shortly.
Louie_T_Intel
Hi chiungliang
sorry for late response.
this question is more related to general compiler issue, and it would be better to let our compiler experts to answer this question.
This forum can help on DL libraries and framework related questions, but you should get better support for intrinsic programming in compiler forum.
Would you mind posting the same question in below forum?
https://software.intel.com/en-us/forums/intel-c-compiler
thanks
ArunJ_Intel
Closing this case as it is adressed in intel-c-compiler forum. Link to question is given below
https://software.intel.com/en-us/forums/intel-c-compiler/topic/849943
