Intel® Quantum SDK
Forum related to Intel Quantum SDK, a full-stack software kit for programming and executing algorithms on simulated quantum hardware.
38 Discussions
Problem with running docker version1.1
JLquantum
Hi, I've been trying to run version 1.1 of the Docker-based Intel Quantum Compiler on my Mac. I followed the instructions and executed the following command to compile the teleport.cpp example: intel-quantum-compiler quantum-examples/teleport.cpp and generated the executable file. However, when I run ./teleport I've received "illegal instruction" message.
I've tried running the version 1.0 and it seems that I could generate the executable file and successfully run it.
System: Mac OS sonoma 14.5
Docker version 26.1.4, build 5650f9b
DrewRisinger
Hello @JLquantum , thanks for the question. Unfortunately, MacOS isn't an officially supported platform for the Intel Quantum SDK. However, we will see if we can diagnose/replicate this issue that you are having.
Can you run ``docker info`` and reply with the results? And can you also supply the full command-line command & message e.g.:
$ ./teleport
[results here]
Thank you!
