Hi, I'm new to FPGA and I'm trying to use the Max 10 FPGA in a project and I'm trying to find a simple solution to use the internal oscillator that is available in MAX 10 device.
My setup is Altera Quartus Prime Lite 16.0 and ModelSim 10.4d. I also observe there is no max10 device library for simulation. Someone can please help on how to use/simulate this internal oscillator for clkout 55MHz. Appreciate if you can share the sample code with testbench in Verilog. Thanks in advance!Link Copied
Solved. Thanks.
--- Quote Start --- Solved. Thanks. --- Quote End --- Hi, may I ask how was that solved ?
Topic Options
