17258 Discussions
Async FIFO 2 Clock code advice - VHDL
Hi all,
I want to ask if someone can advice me an Async FIFO with 2 clocks code in VHDL that works. I know Xilinx provide already build in FIFO IP core, but since I want possibility to migrate my code also to other devices I need a code that I can easy port.
Thank you.
Altera have a DC fifo megafunction. You can generate one with the Megawizard/ipcatalogue or manually instatiate one yourself (if you are familiar with using the altera_mf_components library and reading the documentation).
If you need code that is compilable on both altera and Xilinx, you have 2 options:
1. Make a wrapper around the dc fifo/xilinx fifo that uses a generic to differentiate the manufacturere)
2. Write your own DC fifo (you need to be really careful how you cross the clock domains).
The first option may be the easiest.
Thanks for you answer. But I need the possibilty to use this code also with devices not from Xilinx or Altera. The second option have a problem that I can't really know if my code will be without errors or optimized. So I ask if someone have an opensource Async FIFO.
You could try opencores.org
