Hi, I have one bit output q[7] and I want connect this output to bus B[7..0] in block design file. It is possible? If yes, how? When I try it (I connect output directly to bus), compiler get error "Width mismatch...." . Thank you for your reply...
--- Quote Start --- Hi, I have one bit output q[7] and I want connect this output to bus B[7..0] in block design file. It is possible? If yes, how? When I try it (I connect output directly to bus), compiler get error "Width mismatch...." . Thank you for your reply... --- Quote End --- Hi, you have to specify the name for the connection wire. If your output is the MSB of the bus, you have to use B[7].
--- Quote Start --- Thank you for you reply. I try it (picture OK). It is OK? I have next problem, when I try connect only one bit to bus output (pictures KO). How made this? Scheme is absurdity. It is only for problem preview... --- Quote End --- Hi, you have to name the output of the multiplier e.g. result[15..0]. After that you can split a bit from the bus by naming the net e.g. result[7]. Kind regards GPK
--- Quote Start --- Thanks. This way is right? This solution in pin planer assign all outputs to pins. I want assign only output result[7]... Regards. --- Quote End --- That should work. As long as only result[7] is defined as output. Kind regards GPK
Thanks, I try it.
