16618 Discussions
Cyclone 10 PLLs -> downscale clocks -> how much possible?
amildm
Valued Contributor I
Hi All,
I'm working with Cyclone 10 GX, which has a reference clock of 100MHz .
What lowest frequency could I reach with PLLs using this clock as a reference clock?
I've tried to play with Fractional and Integer PLLs and the lowest frequency I succeeded to reach was 3MHz. Is it possible to reach lower frequencies?
How can I set cascading of the PLLs?
Thank you!
FvM
Valued Contributor III
minimal output frequency is definer bei VCO frequency range and output divider factor. It's about 0.6 MHz. Lower frequencies can be achieved with frequency divider in core logic.
FvM
NazrulNaim_Intel
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
NazrulNaim_Intel
As per the answer provided by user named 'FvM'. The answer can be accepted. Lower frequencies can be achieved with frequency divider in core logic.
Nazrul Naim
