Hi everybody,
I have a question on the synthesis of a multiplier written in VHDL. I have a module (in VHDL) which uses several multipliers. But when I run the Quartus compilation, thoses multipliers are synthesized into "Logic Elements" and not into "Embedded Multiplier 9-bit elements"... How can I "force" Quartus to generate my multipliers into Embedded Multiplier?? (I have lot of Embedded Multiplier elements available so it is not a limitation due to my FPGA..) Thanks!!Link Copied
You can set a synthesis attribute on architecture level. Follow the description in the Quartu software handbook.
architecture rtl of MyUnit is
attribute multstyle : string;
attribute multstyle of rtl : architecture is "dsp";
