Error undefined entity
Hi QuartusII-experts
Error message:
Error: Node instance "u_tone_finder_top" instantiates undefined entity "tone_finder"
Relevant VHDL-code in the file, where "tone_finder" is used (which is not top-level entity):
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.numeric_std.ALL;
USE IEEE.std_logic_arith.ALL;
USE IEEE.std_logic_unsigned.ALL;
USE work.tone_finder_pkg.tone_finder;
-- component for tone finder project
u_tone_finder_top : tone_finder
PORT MAP (
-- System signal
aclr => rst_delayed,
-- 7-Segment Display
ouv8_hex_display => hex_display0_intern,
-- System signal
Clock => r_clk_n_pulses_48k.clk,
-- Control Signals
iuv18_toggle_switch => toggle_switch_in,
-- Audio Codec Interface
isv16_audio_data => sv16_left_audio_data_in,
osv16_tone_data => sv16_audio_data_out
Relevant VHDL-code in "tone_finder.vhd":
LIBRARY IEEE;
USE work.de2_io_definitions_pkg.ALL;
USE work.clock_gen_1536k_pkg.ALL;
PACKAGE tone_finder_pkg IS
COMPONENT tone_finder IS
PORT (
-- System signal
aclr : IN std_logic;
ouv8_hex_display : OUT std_logic_vector(7 DOWNTO 0);
Clock : IN std_logic;
-- Control Signals
iuv18_toggle_switch : IN std_logic_vector(17 DOWNTO 0);
isv16_audio_data : IN std_logic_vector(15 DOWNTO 0);
osv16_tone_data : OUT std_logic_vector(15 DOWNTO 0)
END COMPONENT tone_finder;
END PACKAGE tone_finder_pkg;
--altera translate_off
library IEEE;
use IEEE.std_logic_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity tone_finder is
port (
aclr : in std_logic;
ouv8_hex_display : out std_logic_vector(7 downto 0);
Clock : in std_logic;
iuv18_toggle_switch : in std_logic_vector(17 downto 0);
isv16_audio_data : in std_logic_vector(15 downto 0);
osv16_tone_data : out std_logic_vector(15 downto 0)
end entity tone_finder;
architecture rtl of tone_finder is
component tone_finder_top_GN7422 is
port (
ouv8_hex_display : out std_logic_vector(8-1 downto 0);
iuv18_toggle_switch : in std_logic_vector(18-1 downto 0);
isv16_audio_data : in std_logic_vector(16-1 downto 0);
osv16_tone_data : out std_logic_vector(16-1 downto 0)
end component tone_finder_top_GN7422;
begin
tone_finder_top_GN7422_0: if true generate
inst_tone_finder_top_GN7422_0: tone_finder_top_GN7422
port map(aclr => aclr, ouv8_hex_display => ouv8_hex_display, Clock => Clock, iuv18_toggle_switch => iuv18_toggle_switch, isv16_audio_data => isv16_audio_data, osv16_tone_data => osv16_tone_data);
end generate;
end architecture rtl;
I included the files "tone_finder.vhd" in QuartusII-project (Assignments --> Settings --> Files), but get still the error message above.
Can anybody help me!!! Thank's a lot!!! (I'm wasted nearly 10 hours by now).
Reto
Just delete
--altera translate_on
in the following file!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LIBRARY IEEE;
USE work.clock_gen_1536k_pkg.clock_n_pulses_record;
PACKAGE tone_finder_top_pkg IS
COMPONENT tone_finder_top IS
PORT (
-- System signal
-- Control Signals
END COMPONENT tone_finder_top;
END PACKAGE tone_finder_top_pkg;
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.NUMERIC_STD.all;
entity tone_finder_top is
port (
end entity tone_finder_top;
architecture rtl of tone_finder_top is
port (
begin
end generate;
