17258 Discussions
Error while trying to program EPCS flash in indirect SFL mode
On my new CoreEP4CE10 board, I'm able to upload designs successfully in FPGA Ram using JTAG, but I'm unable to program EPCS Flash using JTAG Indirect SFL mode.
Since this board doesn't have an AS connector, I have no other choice to program using SFL, so I decided to try at command-line, but I got same problem :
We can see below that SFLoader is actually succesfully loaded, but then the JTAG hang and the EPCS is not detected.
Question : Are all boards using same FPGA are compatible with those SFL "Factory default enhanced SFL image" provided ? Should I try to make my own loader using SFL Megafunctions ?
Info: *******************************************************************
Info: Running Quartus II 64-Bit Programmer
Info: Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition
Info: Copyright (C) 1991-2013 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Wed Feb 19 12:11:02 2014
Info: Command: quartus_pgm -m JTAG -o pi;output_files/blinker.jic
Info (213045): Using programming cable "USB-Blaster(Altera) [1-1.3]"
Info (213011): Using programming file output_files/blinker.jic with checksum 0x1A5AF94D for device EP4CE10@1
Info (209060): Started Programmer operation at Wed Feb 19 12:11:03 2014
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x020F10DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Error (209037): JTAG Server can't access selected programming hardware
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Wed Feb 19 12:11:26 2014
Error: Quartus II 64-Bit Programmer was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 286 megabytes
Error: Processing ended: Wed Feb 19 12:11:26 2014
Error: Elapsed time: 00:00:24
Error: Total CPU time (on all processors): 00:00:00
UPDATE :
Following instruction of the Troubleshooting page (http://www.altera.com/cgi-bin/ts.pl?fn=configuration&hi=2-8), I've manually uploaded the SFL into the FPGA, then I've performed an antodetect again, and I'm unable to see the EPCS, I'm only seeing the FPGA itself. Doing the same at the command-line "jtagconfig" only shows the FPGA where I presume the EPCS should also appear, but it doesn't ... I've check power supply voltages, they look fine ... Is that mean my USB Blaster is defective (but why I'm able to upload FPGA properly) ?
