16636 Discussions
Error with SOPC generated files
I am using SDRAM controller in SOPC builder, when compiling the project with QuartusII following error appears.
Any help on how to resolve this.
Error: IO_PIN atom "ddr_dqs_to_and_from_the_ddr_sdram_0[0]" has port DQSUPDATEEN that must be connected to the dqsupdate output of a DLL because the dqs_ctrl_latches_enable parameter is set to true
Error: IO_PIN atom "ddr_dqs_to_and_from_the_ddr_sdram_0[1]" has port DQSUPDATEEN that must be connected to the dqsupdate output of a DLL because the dqs_ctrl_latches_enable parameter is set to true
Thanks a lot,
Sasi
I think you get this error because first you have to assign that pins (ddr_dqs_sdram[0] and [1]) as "Use as regular I/O" in Assignements\Settings\Device\Device and Pin Options\Dual Purpose Pins
try it
I set all the IO's to "Use as regular I/O" option. It did not solve the problem.
Infact the signals are "ddr_dqs_to_and_from_the_ddr_sdram_0[0]" not there in the top module.
Please let me know if you want me to try anything else.
There are two possibilities for this error:
1 - You don't have something connected correctly. Verify that all your DQS pins to/from the DDR2 core are properly connected to top level DQS pins.
2 - Part of your design is being synthesized away because it is not being used. If you've instantiated the DDR2 RAM but you're not actually using it, the logic will be synthesized away and you will get the error shown.
Jake
