I am trying to synthesis a 2KB Ram( with 1024 locations and 16 bit data respectively), in VHDL using Quartus 2 version 12.0 in a 32 bit windows 7 operating system. I am getting message as flow failed, and getting error as cannot fit design, and from the report, what I understand is the tool is trying to compile the design using LE's instead of block rams. Is there any way or option that I can change in the tool, and hence use total memory bits, instead of LEs?. Here is the report that I am getting. Flow Status Flow Failed - Mon Feb 16 16:51:05 2015 Quartus II 32-bit Version 12.0 Build 232 07/05/2012 SP 1 SJ Web Edition Revision Name ping_pong_buffer Top-level Entity Name ping_pong_buffer Family Cyclone II Device EP2C5F256I8 Timing Models Final Total logic elements 56,779 / 4,608 ( 1232 % ) Total combinational functions 24,009 / 4,608 ( 521 % ) Dedicated logic registers 32,826 / 4,608 ( 712 % ) Total registers 32826 Total pins 33 / 158 ( 21 % ) Total virtual pins 0 Total memory bits 0 / 119,808 ( 0 % ) Embedded Multiplier 9-bit elements 0 / 26 ( 0 % ) Total PLLs 0 / 2 ( 0 % ) Thanks, ManojLink Copied
You need to copy one of the patterns that correctly infer ram.
Things like resets or latching the read data on a different clock can cause LEs to be used instead of ram.- Mark as New
Sounds like you didnt follow the template for ram inference, or you did something that a ram cannot do (like reset its contents).
Why not post the code so we can have a look?- Mark as New
--- Quote Start --- Sounds like you didnt follow the template for ram inference, or you did something that a ram cannot do (like reset its contents).Why not post the code so we can have a look? --- Quote End --- Hello Tricky and DSL,Thanks for your reply. Here is my code. I am trying to create a ping-pong buffer( two memories of size 2KB each. Which asserts an interrupt when one of the memories is full). I am attaching my code here with in a notepad file. Thanks
The main problem comes because you didnt register the read address for the ram.
--- Quote Start --- The main problem comes because you didnt register the read address for the ram. --- Quote End --- Hello Tricky, What do you mean by "didn't register the read address for the ram"?. I am sorry, but I am not able to understand that. Can you please elaborate a bit more on that?. Thanks for your time. Regards, Manoj
you use the addr input without registering it first. To infer rams, they require you to have registered read address.
As a beginner, you would probably be better off learning out to use a RAM by generating one from the megawizard.- Mark as New
--- Quote Start --- you use the addr input without registering it first. To infer rams, they require you to have registered read address. As a beginner, you would probably be better off learning out to use a RAM by generating one from the megawizard. --- Quote End --- Thank you. It worked, after registering the read address. Kind Regards, Manoj
I tried using the megawizard first, but it gave me a bunch of signals and statements which I couldn't comprehend. I will dig more into megawizard, and use it.
Thanks, Manoj- Mark as New
--- Quote Start --- Read the ROM and RAM user guide: http://www.altera.co.uk/literature/ug/ug_ram_rom.pdf --- Quote End --- Thank you.
