17249 Discussions
Gate Level Simulation - Can't launch ModelSim-Altera
Hi all
I'm having some difficulty using Modelsim from within Quartus II 14.0 on my linux 64 bit system. Whenever I attempt perform gate level simulation I get the following error from the console:
Error: Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file.
Error: Error: NativeLink simulation flow was NOT successful
Info: Info: For messages from NativeLink scripts, check the file /home/jeremy/altera/14.0/mem_test_nativelink_simulation.rpt
Please note that the EDA tools path is configured correctly. The native link script details the following:
Info: Start Nativelink Simulation process ========= EDA Simulation Settings ===================== Sim Mode : Gate Family : cycloneive Quartus root : /home/jeremy/altera/14.0/quartus/linux64/ Quartus sim root : /home/jeremy/altera/14.0/quartus/eda/sim_lib Simulation Tool : modelsim-altera Simulation Language : vhdl Version : 93 Simulation Mode : GUI Sim Output File : mem_test.vho Sim SDF file : mem_test__vhdl.sdo Sim dir : simulation/modelsim ======================================================= Info: Starting NativeLink simulation with ModelSim-Altera software Sourced NativeLink script /home/jeremy/altera/14.0/quartus/common/tcl/internal/nativelink/modelsim.tcl Warning: File mem_test_run_msim_gate_vhdl.do already exists - backing up current file as mem_test_run_msim_gate_vhdl.do.bak7 Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. Error: Error: NativeLink simulation flow was NOT successful ================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: NONE Nativelink TCL script failed with errorInfo: Can't open transcript file msim_transcript invoked from within "if { nl_postmsg error "Error: Can't launch $tool Simulation software -- make sure the software is pro..." invoked from within "if { error "$::errorCode" "$::errorInfo" } elseif {$script_mode == 0} { post_message..." (procedure "launch_sim" line 109) invoked from within "launch_sim launch_args_hash" ("eval" body line 1) invoked from within "eval launch_sim launch_args_hash" invoked from within "if { set savedCode $::errorCode set savedInfo $::errorInfo error $result $savedInfo $savedCode } else { ..." invoked from within "if { set status 1 if { set savedCode $::errorCode set sav..." (procedure "run_sim" line 78) invoked from within "run_sim run_sim_args_hash" invoked from within "if { set savedCode $::errorCode set savedInfo $::errorInfo error "$result" $savedInfo $savedCode } else { er..." (procedure "run_eda_simulation_tool" line 330) invoked from within "run_eda_simulation_tool eda_opts_hash"
I'm assuming this may be a permissions issue but I can't seem to resolve it. I think the msim_transcript is dynamically generated. Can anyone help me with this issue?
