Hi Guys,
I need to generate vhdl code from java? Is there any way to do it? below is the general behavioral component vhdl program. How do i write in java this kind of vhdl template?please help me. LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY fsm is PORT ( global_clk : IN std_logic; reset : IN std_logic; a : IN std_logic; b : IN std_logic; c : OUT std_logic); END fsm; ARCHITECTURE fsm_A OF fsm IS type fsmstatetype is ( state1, state2, state3); BEGIN fsm_P : PROCESS (reset, global_clk) VARIABLE testvariable : std_logic := '0'; VARIABLE fsmstate : fsmstatetype:= state1; BEGIN IF (reset = '1') THEN testvariable:= '0'; fsmstate := state1; ELSIF (global_clk'event and global_clk = '1') THEN CASE fsmstate IS WHEN state1 => IF (a='1') THEN and not (b='1') THEN testvariable := '1'; fsmstate := state2; ELSE fsmstate := state1; END IF; WHEN state2 => IF (a='1') THEN and (b='1') THEN testvariable := '0'; fsmstate := state3; ELSE fsmstate := state2; END IF; WHEN state3 => IF not (a='1') THEN and not (b='1') THEN testvariable := '1'; fsmstate := state1; ELSE fsmstate := state3; END IF; END CASE; END IF; c <= testvariable; END PROCESS; END fsm_A;Link Copied
Vhdl and java are different things and converting from one to the other is not trivial. You need to understand digital logic to convert to vhdl
--- Quote Start --- Vhdl and java are different things and converting from one to the other is not trivial. You need to understand digital logic to convert to vhdl --- Quote End --- I have a certain java file, when i run that file I get a window where i have to select component and type of component weather it is behavioral or structural component,and i have to also select states and transitions if it is behavioral and then i have to export it as vhdl after exporting it should generate .vhd file. for example the below generated file is for behavioral(fsm) .vhd file which was generated using python but i have to do in java. -- fsm for VHDL export by SpecScribe LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY fsm is PORT ( global_clk : IN std_logic; reset : IN std_logic; a : IN std_logic; b : IN std_logic; c : OUT std_logic); END fsm; ARCHITECTURE fsm_A OF fsm IS type fsmstatetype is ( state1, state2, state3); BEGIN fsm_P : PROCESS (reset, global_clk) VARIABLE testvariable : std_logic := '0'; VARIABLE fsmstate : fsmstatetype:= state1; BEGIN IF (reset = '1') THEN testvariable:= '0'; fsmstate := state1; ELSIF (global_clk'event and global_clk = '1') THEN CASE fsmstate IS WHEN state1 => IF (a='1') THEN and not (b='1') THEN testvariable := '1'; fsmstate := state2; ELSE fsmstate := state1; END IF; WHEN state2 => IF (a='1') THEN and (b='1') THEN testvariable := '0'; fsmstate := state3; ELSE fsmstate := state2; END IF; WHEN state3 => IF not (a='1') THEN and not (b='1') THEN testvariable := '1'; fsmstate := state1; ELSE fsmstate := state3; END IF; END CASE; END IF; c <= testvariable; END PROCESS; END fsm_A;
learn vhdl as said Tricky
you talking about how create program for one program language from another- Mark as New
It sounds like the Java file you have is some program that generates some VHDL for you. I have no idea what this program is - it was probably somebody's hobby project...
Is this the program you are talking about?
http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=4641456 In general, re-implementing software written in Python in Java shouldn't be very complicated, but it does require knowledge of both languages. And I don't think this task even needs any familiarity with VHDL itself. I'm not sure why you need VHDL and Java, but if you can get away with Verilog, you can always consider Chisel (which is built on Scala (which is built on Java)). From there, you ought to be able to cobble together the pieces to have a piece of Java that programmatically generates Verilog, if that's what you're trying to accomplish.
