How to see issue: File -> New -> Quartus II Project click next until family and device settings screen (page 3 of 5) family -> MAX II There is no option for device EPM2210GF256C3N Note: there is an option for EPM2210F256C3N which is the 3.3 v version, where I want the 1.8 v version (with the G) Does anyone know if I can use the 3.3 V version, or how to fix this issue? I already have boards with the 1.8 V chip. Thanks, Angela
Hi Angela: That's really interesting. I only see the smaller Z devices with the 1.8V core.
I checked Quartus versions 12.0 -> 13.1 and none of the G variations came up in any of these versions. I also tried to change the core voltage to 1.8V in the device and pin options and that is also locked out. I haven't worked with this family much. So I don't know the why it would be missing from the standard devices lists. (I'm using the full licensed version of quartus, so it should be there).. I suggest you open a support case, or contact your FAE if no one else on this site is able to help. Usually as device support is dropped, it's listed on https://www.altera.com/download/sw/dnl-sw-index.jsp when you select by device. But Max II is still showing as fully supported. Pete- Mark as New
I have same problem, but with device EPM570GM100I5N. It's realy strange and I've wrote in mySuppor, so I'm waiting for their answer...
Ok. I just got a answer from my FAE on this issue:
o target your device, manually enter the part in the Quartus II Settings File (.qsf) by performing the following steps: Close the project Open <project>.qsf in a text editor Locate the line set_global_assignment -name DEVICE <device code> Change the setting to the device you are targeting As an example, for the part EPM2210GF256I5, the syntax would be set_global_assignment -name DEVICE EPM2210GF256I5 Exclude the N (lead-free) indicator if that is applicable to your part Save the updated file To verify your changes, perform the following steps: Open your project On the Assignments menu, click Devices Verify that Target device has the Other: option selected and is set to your device In this example, EPM2210GF256I5 Why quartus doesn't list the G variation I don't know. But it does work. I compiled a simple design just to verify and under device and pin options for Voltage, it lists the VCCINT as 1.8V instead of the 3.3V for the F variation that I initially started the project with. Pete- Mark as New
Thanks, it's really works for EPM570GM100I5 too.
And anybody know, does it really work with real deviсe when I'll programm it?
And anybody know, does it really work with real device when I'll programm it?
