17267 Discussions
Modelsim error: Failed to open file "mem_init.mif" for reading?
Hey guys:
I instantiated a synchronous RAM megafunction in my project and successfully compiled in Quartus and Modelsim. But when I run the simulation there is no waveform. I checked the Modelsim transcript it shows an error and two warnings:
# ** Warning: (vsim-3534) [FOFIR] - Failed to open file "mem_init.mif" for reading.# No such file or directory. (errno = ENOENT) : /opt/altera/13.0sp1/quartus/eda/sim_lib/altera_mf.v(187)# Time: 0 ps Iteration: 0 Instance: /proc_testbench/DUV_2/altsyncram_component# ERROR: cannot read mem_init.mif.# ** Warning: (vsim-7) Failed to open readmem file "mem_init.ver" in read mode.# No such file or directory. (errno = ENOENT) : /opt/altera/13.0sp1/quartus/eda/sim_lib/altera_mf.v(45501)
It seems that Modelsim cannot find the initial memory file. How can I solve the problem?
Thanks in advance!
Yumeng
--- Quote Start ---
Hey guys:
Thanks in advance!
Yumeng
--- Quote End ---
A common problem.
quickest way is to insert your mif in simulation folder.
The problem arises from mif path being correct for ip but not from sim folder.
the mif file needs to be in the same directory that the simulation is run from.
Thank you so much! It works!
