17268 Discussions
New component in SOPC Builder 9.0
I switched to Quartus 9.0 from 6.1.
In SOPC Builder, I use New Component editor for external RAM but have problems.
I created Avalon MM tristate slave and signals for custom component:
address 18 input
data 16 bidir
byteenable_n 2 input
chipselect_n 1 input
read_n 1 input
write_n 1 input
This component was instantiated as a verilog file and connected to the tristate bridge.
No warning were issued and the system was generated successfully.
But only data port appeared in .bdf file.
In another component I created Avalon MM slave and signals:
address,writedata and write_n, but there is no port in top level design.
How to resolve this problem?
thanks,
To be seen from outside, a port has to be declared as export in Avalon Conduit interface. (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
So declare a signal according to its function for the processor side (e.g. address; Avalon MM slave), and declare one as export (Avalon Conduit) for the external side, and make the connection between them inside your component.
Jérôme
