17268 Discussions
PLEASE Help about Basic LED Blink
Hi, I'm beginner in VHDL, trying to get a true simulation result.
------------THIS'S THE CODE---------
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity ensonled is port
CLK_50MHz: in std_logic;
myLED: out std_logic
end ensonled;
architecture ensonled of ensonled is
signal counter:integer range 0 to 24999999;
signal CLK_1Hz:std_logic :='0';
begin
prescaler: process(CLK_50MHz)
begin
if rising_edge(CLK_50MHz) then
if counter<25000000 then
counter<=counter+1;
else
CLK_1Hz <= not CLK_1Hz;
counter <= 0;
end if;
myLED<=CLK_1Hz;
end if;
end process prescaler;
end ensonled;
THIS'S THE TEST BENCH CODE-------------
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY ensonled_vhd_tst IS
END ensonled_vhd_tst;
ARCHITECTURE ensonled_arch OF ensonled_vhd_tst IS
-- constants
-- signals
SIGNAL CLK_50MHz : STD_LOGIC;
SIGNAL myLED : STD_LOGIC;
COMPONENT ensonled
PORT (
CLK_50MHz : IN STD_LOGIC;
myLED : OUT STD_LOGIC
END COMPONENT;
BEGIN
i1 : ensonled
PORT MAP (
-- list connections between master ports and signals
CLK_50MHz => CLK_50MHz,
myLED => myLED
--CLK_50MHz <= not CLK_50MHz after 20 ns/2;
clk_gen_proc : process
begin
if CLK_50MHz /= '1' then CLK_50MHz <= '1';
else CLK_50MHz <= '0';
end if;
wait for 20 ns;
end process;
END ensonled_arch;
In simulation, I always getting 'myLED' as 0 after first rising edge of Clock. And additionally, for one time, I got a result like I desired, but whenever i tried it out over again, failed. Never changed the code, it was same. But it doesn't give a damn any more. Why? Please help me.
https://alteraforum.com/forum/attachment.php?attachmentid=14932&stc=1
https://alteraforum.com/forum/attachment.php?attachmentid=14932&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14932&stc=1
counter is always going to be less than 25000000 because you set its max range to 24999999.
ahh Thanks, though i've changed it, unfortunately giving same result:( what's wrong?
how long are you running the simulation for?
You need to run it for more than 500 ms for myLED to go high.
