Here is the code I have
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity Stopwatch is
port (clk1 : in std_logic;
run : in std_logic;
res : in std_logic;
tenths : out std_logic_vector(3 downto 0);
seconds : out std_logic_vector(3 downto 0);
tens : out std_logic_vector(3 downto 0);
LED1 : out std_logic_vector(6 downto 0);
LED2 : out std_logic_vector(6 downto 0);
LED3 : out std_logic_vector(6 downto 0)
end Stopwatch;
architecture Behavioral of Stopwatch is
signal tnt,sec,ten : integer range 0 to 9 :=0;
signal count : integer :=1;
signal clk : std_logic :='0';
signal runs : std_logic :='0';
begin
tenths <= conv_std_logic_vector(tnt,4);
seconds <= conv_std_logic_vector(sec,4);
tens <= conv_std_logic_vector(ten,4);
--clk generation.For 100 MHz clock this generates 1 Hz clock.
process(clk1)
begin
if(clk1'event and clk1='1') then
count <=count+1;
if(count = 3) then
clk <= not clk;
count <=1;
end if;
end if;
end process;
process(clk) --period of clk is 1 second.
begin
if (res = '1') then
tnt<= 0;
sec<= 0;
ten<= 0;
end if;
if (run='1' and runs='0') then
runs <='1';
ELSIF (run='1' and runs='1') then
runs <='0';
end if;
if(clk'event and clk='1') then
if (runs='1')then
tnt <= tnt+ 1;
end if;
if(tnt = 9) then
tnt<=0;
sec <= sec + 1;
if(sec = 9) then
ten <= ten + 1;
sec <= 0;
if(ten = 9) then
ten <= 0;
end if;
end if;
end if;
end if;
If (tnt = 0) Then
LED1 <= "0000001" ;
ELSIF (tnt = 1) Then
LED1 <= "1001111";
ELSIF (tnt = 2) Then
LED1 <= "0010110";
ELSIF (tnt = 3) Then
LED1 <= "0000110";
ELSIF (tnt = 4) Then
LED1 <= "1001100";
ELSIF (tnt = 5) Then
LED1 <= "0100100";
ELSIF (tnt = 6) Then
LED1 <= "0100000";
ELSIF (tnt = 7) Then
LED1 <= "0001111";
ELSIF (tnt = 8) Then
LED1 <= "0000000";
ELSIF (tnt = 9) Then
LED1 <= "0001100";
end if ;
If (sec = 0) Then
LED2 <= "0000001" ;
ELSIF (sec = 1) Then
LED2 <= "1001111";
ELSIF (sec = 2) Then
LED2 <= "0010110";
ELSIF (sec = 3) Then
LED2 <= "0000110";
ELSIF (sec = 4) Then
LED2 <= "1001100";
ELSIF (sec = 5) Then
LED2 <= "0100100";
ELSIF (sec = 6) Then
LED2 <= "0100000";
ELSIF (sec = 7) Then
LED2 <= "0001111";
ELSIF (sec = 8) Then
LED2 <= "0000000";
ELSIF (sec = 9) Then
LED2 <= "0001100";
end if ;
If (ten = 0) Then
LED3 <= "0000001" ;
ELSIF (ten = 1) Then
LED3 <= "1001111";
ELSIF (ten = 2) Then
LED3 <= "0010110";
ELSIF (ten = 3) Then
LED3 <= "0000110";
ELSIF (ten = 4) Then
LED3 <= "1001100";
ELSIF (ten = 5) Then
LED3 <= "0100100";
ELSIF (ten = 6) Then
LED3 <= "0100000";
ELSIF (ten = 7) Then
LED3 <= "0001111";
ELSIF (ten = 8) Then
LED3 <= "0000000";
ELSIF (ten = 9) Then
LED3 <= "0001100";
end if ;
end process ;
end Behavioral;
And I keep getting the error saying cannot infer register for tnt because it does not hold value outside of clock edge. The problems go away when i remove the code for res and runs but I want res to be a button that resets everything to 0 when pressed and I want run to be the button that starts and stops the timer. What am I doing wrong here?
The synthesizer could be confused by the construction you used for the clocked process. A clocked process should always be constructed like this:process(clk,reset)
if (reset = '1') then
signals reset
elsif rising_edge(clk) -- or (clk'event and clk='1')
instructions
end if;
end process;
Okay, so thats how I should set up the reset but how is the start stop button implemented? It seems like it will just keep running on its own with the way the second if is set up
you can sample the start and stop buttons in the clocked part of the process. You can have for example an 'on' signal that you set to 1 when you detect the start button has been pressed and back to 0 when you detect the stop button has been pressed. Then only update your counter when the 'on' signal is 1.
