Problem with generate
Hi all,
In one of the state of the state machines I was writing, I used generate-endgenerate
for loop to give values of some outputs. But I got the error like:
Error (10170): Verilog HDL syntax error at SystemCU.v(235) near text "generate"; expecting "end"
Error (10170): Verilog HDL syntax error at SystemCU.v(244) near text "endgenerate"; expecting "end"
Could someone help me on this... Thanks in advance.
STATE_LDR1: begin PC_BUS=0; ALU_BUS=1; POFF_BUS=0; MDR_BUS=0; REG_MUX1=4'b0000; REG_MUX2=4'b0000; REG_MUX3=0; ALU_CTR=ALU_NOTHING; LD_IR=0; LD_MDR=0; LD_ALU=0; Reset_PC=1; LD_PC=0; PC_MUX=0; LD_MAR=0; MEM_RW=0; LD_REG]=1; generate genvar i; for(i=0;i<16;i=i+1) begin:LDR0_GEN if(i!=IR) LD_REG=0; end endgenerate nextstate=STATE_0; end
the genvar declaration has to be placed before generate for
