Q:Dynamic PowerAnalysis
Help!
I have completed my FPGA design with dspbuilder. I used the 'Signal Compiler' in it to generate a project for using in quartus. Now I want to analyze the power with the powerplay in quartus. but i found the dynamic power analysis in report is zero. I saw some information that I should use modelsim to generate a '.vcd' file and import it into powerplay to get dynamic power analysis. Unfortunately, I fail again in simulating. My design only have two inputs 'clk' and 'aclr', and an 16 bits output. I wrote the testbench like this:
init : PROCESS
-- variable declarations
BEGIN
aclr<='1';
-- code that executes only once
WAIT;
END PROCESS init;
always : PROCESS
constant clk_period:time:=20ns;
constant DELAY : time := 0 fs;
-- optional sensitivity list
BEGIN
-- code executes for every event on sensitivity list
wait for DELAY;
loop
Clock<='0';
wait for clk_period/2;
Clock<='1';
end loop;
WAIT;
END PROCESS always;
I can get the expected wave for clk and aclr, but the output is always 'u', the wave is a red line.
now i don't konw how to get correct simulation result or there's any other method to get correct power analysis?
Thank you for your read and help in advance.
